mpls network and vlans
Mar 25th, 2010
Hi, we currently have an mpls network setup (where everything runs into our switch stack) and are going to be moving two of the sites off the mpls over to a p2p connection.  All of our mpls sites are currently setup with the same 2 vlans 192.168.41.x (vlan 41) for data and 192.168.51.x (vlan 51) wireless.  What I was planning on doing was setting up two more vlans on our switch stack (one for each new p2p) but leaving the 41 and 51 vlans at the sites alone.  Is this going to cause any issues.
Linda
Reza Sharifi Thu, 03/25/2010 - 15:00
Hi Linda,
If I understand you question correctly, you are going from 2 vlans to 4.  That should not cause any problem as long as you are adding the new vlans/subnets to whatever routing protocol you are using.
Reza
