RVS4000 Incoming Logs are Empty
Mar 25th, 2010
Greetings!
We have a RVS4000 with the latest firmware V1.3.1.0 and CPU version of STAR 9202.
When I enable the incoming and outgoing logs only the outgoing shows any traffic.
I also did a syslog and the captured logs only show outgoing, no incoming. Is the router bad?
I've reset it back to the factory defaults and currently it's running between this pc and my network just to test.
Anyone seen this before or should I return it? Thanks!
Te-Kai Liu Thu, 03/25/2010 - 14:30
  • Gold, 750 points or more
My experience with RVS4000 tells that the router only logs incoming connection associated with an ACL rule or port forwarding rule. By default the router blocks all incoming connection without logging these attempts.
manlytrash Thu, 03/25/2010 - 19:03
But it logs my outgoing web/rdp/other traffic and not one single incoming unless I port forward to a ip? Thats a wothless router and I'm taking it back. Thanks.
By the way, it doesn't LOG ANY INCOMING!!!!! NOTHING!!!!!
