CUCM BE upgrade
Mar 25th, 2010
To avoid the field notice, I want to upgrade my cucmbe from 7.0.2 to 7.1.3
I have few question
1. I would think there is a seperate software for it, where can I download it from?
2. Does the cucm field notice be applicable for cucmbe as well?
Kads
Jaime Valencia Thu, 03/25/2010 - 14:07
Not really:
For instructions on upgrading a  Cisco Unified CMBE system, see the "Software Upgrades" chapter of the  applicable version of the Cisco Unified  Communications Operating System Administration Guide at http://www.cisco.com/en/US/products/ps7273/prod_maintenance_guides_list.html.
Note that when upgrade files are available for download on Cisco.com,  the files can be used to upgrade Cisco Unity Connection, Cisco Unified  Communications Manager, and Cisco Unified Communications Manager  Business Edition. The files can be downloaded from the Connection or  Cisco Unified CM downloads page. (For download instructions from the  Connection downloads page, see the "Downloading Software for an Upgrade  from Cisco Unity Connection 7.0 or 2.1(2) or Later to 7.1" section of  the applicable release notes at http://www.cisco.com/en/US/products/ps6509/prod_release_notes_list.html.)
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucmbe/rel_notes/7_1_3/713cucmbern.html#wp46418
As for a FN you need to provide a link or reference to understand which one you're referring to.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
