UC520 issue swith stcapp and fxs ports
Mar 25th, 2010
I have a UC520 with an analog phone hanging off of a fxs port.
The ephone associated with the fxs port will not register. When you take the analog phone off hook the user hears a fast busy. At the same time a console message is displayed which says somethign to the effect of "the service stcapp on dial-peer 1 cannot be found." Below is a portion of the config.
Thanks!!
stcapp ccm-group 1
stcapp feature access-code
stcapp feature speed-dial
isdn switch-type basic-net3
voice call send-alert
voice rtp send-recv
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip access-group 101 in
ip nat inside
ip virtual-reassembly
interface FastEthernet0/0
ip address 192.168.220.1 255.255.255.0
duplex auto
speed auto
interface Integrated-Service-Engine0/0
ip unnumbered Loopback0
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
voice-port 0/0/0
timeouts ringing infinity
caller-id enable
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
compand-type a-law
bearer-cap Speech
voice-port 0/1/1
compand-type a-law
bearer-cap Speech
voice-port 0/2/0
translation-profile incoming default
supervisory disconnect dualtone pre-connect
pre-dial-delay 0
echo-cancel coverage 32
no vad
timeouts call-disconnect 2
timeouts wait-release 2
timing hookflash-out 250
connection plar opx 011
description xxxxxxx
caller-id enable
voice-port 0/2/1
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local FastEthernet0/0
sccp ccm 192.168.220.1 identifier 1 version 3.1
sccp ccm group 1
associate ccm 1 priority 1
switchback method graceful
signaling dscp af31
dial-peer voice 5 pots
description ** MOH Port **
preference 7
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 100 voip
description AUTOATTEND
destination-pattern 003
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 101 voip
description VM
destination-pattern 002
b2bua
codec g711ulaw
no vad
dial-peer voice 102 voip
description VM
destination-pattern 001
b2bua
codec g711ulaw
no vad
dial-peer voice 50 pots
description LONGDISTANCE
destination-pattern 1[2-9]..[2-9]......
direct-inward-dial
port 0/2/0
no sip-register
dial-peer voice 51 pots
destination-pattern [2-9]......
direct-inward-dial
port 0/2/0
no sip-register
dial-peer voice 52 pots
description 911
destination-pattern 911
direct-inward-dial
port 0/2/0
no sip-register
dial-peer voice 105 voip
description 3260939
destination-pattern 011
b2bua
codec g711ulaw
no vad
dial-peer voice 1 pots
service stcapp
port 0/0/0
no dial-peer outbound status-check pots
telephony-service
video
em logout 0:0 0:0 0:0
max-ephones 22
max-dn 88
ip source-address 192.168.220.1 port 2000
auto assign 10 to 27
auto assign 5 to 8 type anl
calling-number initiator
service phone videoCapability 1
timeouts interdigit 3
system message UC520
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
load 7914 S00105000200
load 7902 CP7902080002SCCP060817A
load 7906 SCCP11.8-2-2SR2S
load 7911 SCCP11.8-2-2SR2S
load 7921 CP7921G-1.0.3
load 7931 SCCP31.8-2-2SR2S
load 7936 cmterm_7936.3-3-13-0
load 7960-7940 P00308000500
load 7941 SCCP41.8-2-2SR2S
load 7941GE SCCP41.8-2-2SR2S
load 7942 SCCP42.8-3-2S
load 7945 SCCP45.8-3-2S
load 7961 SCCP41.8-2-2SR2S
load 7961GE SCCP41.8-2-2SR2S
load 7962 SCCP42.8-3-2S
load 7965 SCCP45.8-3-2S
load 7970 SCCP70.8-2-2SR2S
load 7971 SCCP70.8-2-2SR2S
load 7975 SCCP75.8-3-2S
time-zone 13
voicemail 001
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 $1$K6Qb$m2rQfTHmtB9VfvaAuosOQ.
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
create cnf-files version-stamp 7960 Mar 24 2010 18:21:50
ephone-template 15
button-layout 7931 2
ephone-dn 1
number 005
label Kitchen
description Kitchen
name Kitchen
call-forward busy 001
call-forward noan 001 timeout 10
hold-alert 30 originator
ephone-dn 2
number 010
label Cordless Phones
description Cordless Phones
name Cordless Phones
ephone-dn 3
number 004
mwi on
ephone-dn 4
number 020
label Page All
name PageAll
paging ip 239.1.1.1 port 2000
ephone-dn 6 dual-line
number 302 no-reg primary
label 302
description PhoneB Analog
name PhoneB Analog
ephone-dn 7 dual-line
number 303 no-reg primary
label 303
description PhoneC Analog
name PhoneC Analog
ephone-dn 8 dual-line
number 304 no-reg primary
label 304
description PhoneD Analog
name PhoneD Analog
ephone-dn 9
number BCD no-reg primary
description MoH
moh ip 239.10.16.8 port 2139 out-call ABC
ephone-dn 10 dual-line
number 006
label Garage
description Garage
name Garage
ephone 2
device-security-mode none
mac-address B8FA.B54C.0000
max-calls-per-button 2
paging-dn 4
type anl
button 1:2
ephone 3
mac-address B8FA.B54C.0002
type anl
button 1:7
ephone 4
mac-address B8FA.B54C.0003
type anl
button 1:8
ephone 5
video
mac-address 001F.CA34.AC3F
username "Kitchen" password null
paging-dn 4
type 7965
button 1:1
ephone 6
video
mac-address 0022.9004.4EEC
username "Garage" password null
paging-dn 4
type 7942
button 1:10
ephone-hunt 1 sequential
pilot 011
list 010, 005, 006
preference 1 secondary 1
djh278778 Mon, 05/17/2010 - 14:52
I don't see "stcapp" in your global configuration. This turns the service on. If that doesn't do it, my next question is:      Is the network flat(where is your voice VLAN)?
