what is Zflash: under file systems 3550 switch
Answered Question
Mar 25th, 2010
Hi all,
i upgrade the ios in 3550 switch
when i do
Switch#sh File systems
File Systems:
     Size(b)     Free(b)      Type  Flags  Prefixes
*   15998976     6282752     flash     rw   flash:******************************
           -           -    opaque     ro   bs:
           -           -    opaque     rw   vb:
    15998976     6282752   unknown     rw   zflash:**********************
           -           -    opaque     rw   system:
           -           -    opaque     rw   tmpsys:
      393216      389278     nvram     rw   nvram:
           -           -    opaque     ro   xmodem:
           -           -    opaque     ro   ymodem:
i see  2 ios image of same size but one is of type flash and other is unknown
Anybody know what is zflash?  and is it ok if i delete zflash?
thanks
mahesh
Correct Answer by Jon Marshall about 6 years 10 months ago
mahesh18 wrote:
Hi Jon
i did this
Switch#verify flash:c3550-ipservicesk9-mz.122-44.SE6.bin
%Error verifying flash:c3550-ipservicesk9-mz.122-44.SE6.bin (No such file or dir
ectory)
Switch#
thanks
mahehs
Mahesh
Did a quick search and it seems that using the verify command that way might not be supported on all switches.
Jon
Overall Rating: 5 (1 ratings)
johnnylingo Thu, 03/25/2010 - 16:11
Weird.   I'm not familiar enough with the 3550 to tell you for sure.
What does "dir all-filesystems" show?
mahesh18 Thu, 03/25/2010 - 16:15
Here is output
Switch#dir all-filesystems
Directory of flash:/
    2  -rwx     9707290  Mar 25 2010 16:37:50 -06:00  c3550-ipservicesk9-mz.122-
44.SE6.bin
    3  -rwx        2838  Mar 25 2010 16:54:23 -06:00  config.text
  406  -rwx         285  Feb 28 1993 17:14:38 -07:00  info.ver
  407  -rwx         580  Mar 21 2010 15:09:27 -06:00  vlan.dat
    4  -rwx          24  Mar 25 2010 16:54:23 -06:00  private-config.text
    5  -rwx        1048  Mar 25 2010 16:54:23 -06:00  multiple-fs
    6  -rwx           0  Mar 22 2010 15:34:22 -06:00  env_vars
    7  -rwx          42  Mar 22 2010 15:34:22 -06:00  system_env_vars
15998976 bytes total (6282752 bytes free)
Directory of zflash:/
44.SE6.bin
Directory of system:/
    2  -r--           0                      default-running-config
    4  dr-x           0                      memory
    1  -rw-        2838                      running-config
    3  dr-x           0                      vfiles
No space information available
Directory of tmpsys:/
No files in directory
Directory of nvram:/
  380  -rw-        2838                      startup-config
  381  ----          24                      private-config
    1  -rw-           0                      ifIndex-table
393216 bytes total (389278 bytes free)
Also directory of system and nvram shows no date ?
thanks for reply
Jon Marshall Thu, 03/25/2010 - 16:54
Mahesh
zflash is a read-only copy of flash. I doubt whether you will be able to delete it. I think it is an internal filesystem to the switch that is not configurable by the network administrator.
Jon
mahesh18 Thu, 03/25/2010 - 17:24
Hi jon
Thanks for reply again.
one last thing on this  when i run command
verify /md5 c3550-ipservicesk9-mz.122-44.SE6.bin  it verifies flash  --
.................................................Done!
verify /md5 (flash:c3550-ipservicesk9-mz.122-44.SE6.bin) = a829d14ab1ccd3ecf77b99d025d188ce
but when i run the command
Switch#verify flashc3550-ipservicesk9-mz.122-44.SE6.bin
%Error verifying flash:flashc3550-ipservicesk9-mz.122-44.SE6.bin (No such file o
r directory)
Switch#
It does not work do you know why is this so?
thanks
mahesh
Jon Marshall Thu, 03/25/2010 - 17:45
Mahesh
r directory)
Switch#
Try
verify flash:c3550-ipservicesk9-mz.122-44.SE6.bin  ie. add the ':' between flash and the image name.
Jon
mahesh18 Thu, 03/25/2010 - 17:52
Hi Jon
i did this
ectory)
Switch#
thanks
mahehs
Correct Answer
Jon Marshall Thu, 03/25/2010 - 18:08
mahesh18 wrote:
Hi Jon
i did this
ectory)
Switch#
thanks
mahehs
Mahesh
Jon
