OSPF Routing Protocol
Mar 25th, 2010
I configured the OSPF as shown on the diagram in the attachment.
Senorio 1: All the ports on the switch initally on default VLAN and there was no problem in OSPF neigbour formation.
Senorio 2: I confiured the 2 different netwrok on 2 different VLAN. I though the OSPF Neibour will fail because there is no routing between the VLAN. But the neibour formation was successful. i even reload the routers.
My question is how did the routing protocols were excanged between the 2 Broadcast domain (i.e. Between 2 VLAN) when there is no routing between the 2 broadcast domain.
Logesh
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
Jon Marshall Thu, 03/25/2010 - 17:01
Logesh
Can't read your attachments. Could you just post the configs + a jpg/png of the setup.
Jon
lmanavalan Thu, 03/25/2010 - 17:25
Please find the diagram in the attachment and below is the configuration
R1: Configuration
interface FastEthernet0/0
ip address 172.30.49.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.1.14.1 255.255.255.252
duplex auto
speed auto
shutdown
router ospf 1
log-adjacency-changes
network 172.30.49.0 0.0.0.255 area 0
network 10.1.14.0 0.0.0.3 area 0
R4: Configuration
ip address 172.30.50.4 255.255.255.0
duplex auto
speed auto
ip address 10.1.14.2 255.255.255.252
duplex auto
speed auto
router ospf 1
network 172.30.50.0 0.0.0.255 area 0
network 10.1.14.2 0.0.0.0 area 0
R3: Configuration
ip address 172.30.50.3 255.255.255.0
duplex auto
speed auto
router ospf 1
R2: Configuration
ip address 172.30.50.2 255.255.255.0
duplex auto
speed auto
router ospf 1
Senorio 1: Switch configuration
hostname Switch
description toR4
interface FastEthernet0/2
description toR3
interface FastEthernet0/3
  description toR2
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
  description toR4
interface FastEthernet0/24
  description toR1
interface Vlan1
no ip address
shutdown
Senorio 2: Switch configuration
hostname Switch
description toR4
switchport access vlan2
description toR3
  description toR2
  description toR4
  switchport access vlan3
  description toR1
interface Vlan 2
ip address 10.1.1.1 255.255.255.0
interface Vlan 3
ip address 10.2.2.2 255.255.255.0
Logesh
Jon Marshall Thu, 03/25/2010 - 17:37
Thanks for that.
Can you post "sh ip ospf neighbors" from all routers.
Jon
Tharak Abraham Thu, 03/25/2010 - 22:01
Logesh,
Did you use vlan SVI's on the switch and advertise the IP in OSPF ?
Please do a sh ip ospf neigh on the routers and paste it here..
lmanavalan Thu, 03/25/2010 - 23:14
sh ip ospf neighbor
R1#sh ip ospf neighbor
Neighbor ID     Pri   State           Dead Time   Address         Interface
172.30.50.4       0   FULL/  -        00:00:33    10.1.14.2       FastEthernet0/1
R4#sh ip os neighbor
172.30.50.2       1   FULL/DROTHER    00:00:39    172.30.50.2     FastEthernet0/0
172.30.50.3       1   FULL/BDR        00:00:34    172.30.50.3     FastEthernet0/0
172.30.49.1       0   FULL/  -        00:00:34    10.1.14.1       FastEthernet0/1
R2#sh ip ospf neighbor
172.30.50.3       1   FULL/BDR        00:00:35    172.30.50.3     FastEthernet0/0
172.30.50.4       1   FULL/DR         00:00:35    172.30.50.4     FastEthernet0/0
R3#sh ip ospf neighbor
172.30.50.2       1   FULL/DROTHER    00:00:31    172.30.50.2     FastEthernet0/0
172.30.50.4       1   FULL/DR         00:00:36    172.30.50.4     FastEthernet0/0
