question about UDP 16667
Answered Question
Mar 25th, 2010
  • Silver, 250 points or more
I have a quick question about UDP 16667, it is said in configuration guide that:
“IPSec encryption can also be configured for the inter-controller mobility messages, in which case port 16667 is used.”
My question is how to configure IPSec to support it? I can’t find any document describe this. Thanks for any input!
Correct Answer by Scott Fella about 7 years 3 months ago
That is the only command required if you want to enable secure mobility.  So UPD port 16667 will need to be allowed, but 16666 doesn't need to be since you are using secure mobility.  Now depending on how your setup, you will need other ports allowed if required:
Q. What ports do I need to permit for Lightweight Access Point Protocol (LWAPP) communication when there is a firewall in the network?
A. You must enable these ports:
  • Enable these UDP ports for LWAPP traffic:
    • Data - 12222
    • Control - 12223
  • Enable these UDP ports for Mobility traffic:
    • 16666 - Secured Mode
    • 16667 - Unsecured Mode
Mobility and data messages are usually exchanged through EtherIP packets. IP protocol 97 must be allowed on the firewall to allow EtherIP packets. If you use ESP to encapsulate mobility packets, you have to permit ISAKMP through the firewall when you open UDP port 500. You also have to open the IP protocol 50 to allow the encrypted data to pass through the firewall.
These ports are optional (depending on your requirements):
  • TCP 161 and 162 for SNMP (for the Wireless Control System [WCS])
  • UDP 69 for TFTP
  • TCP 80 and/or 443 for HTTP or HTTPS for GUI access
  • TCP 23 and/or 22 for Telnet or secure shell (SSH) for CLI access
Overall Rating: 5 (1 ratings)
Scott Fella Thu, 03/25/2010 - 19:59
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
That might be a good question for TAC or one of the Cisco engineers on this forum.  I have seen that listed in the 3.2 code docs way back when and really have not seen any supporting documents on how to configure this feature if it even exist:)
bbxie Thu, 03/25/2010 - 22:15
What I can find is to use “config mobility secure-mode enable” to use 16667 instead of 16666, however nothing talked about IPSec itself. Usually IPSec has a lot of parameters tunable, but I can't find out any document describing how to configure them. It seems for WLC all the parameters are fixed and not changable; all the IPSec packets are encapsulated with UDP 16667, we don't need to configure anything else in the WLC other than the above command, for all the network equipments(for example Firewall) between the two WLC, only need to allow UDP 16667.  I just want to confirm this.
Correct Answer
Scott Fella Fri, 03/26/2010 - 04:43
  • Hall of Fame,
    2017 Wireless
    • Data - 12222
    • Control - 12223
  • UDP 69 for TFTP
bbxie Sun, 03/28/2010 - 21:34
Thanks Scott! Does UDP16667 means ESP will be used and the firewall not only need to allow UDP 16667/IP protocol 97, but also UDP 500 and IP protocol 50?
Scott Fella Mon, 03/29/2010 - 05:24
  • Hall of Fame,
    2017 Wireless
No problem... just open UDP 16667 on the FW from WLC to WLC.  ESP is that whole thing about securing mobility messages using ipsec:)
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
