Does cisco 2911 router onboard 10/100/1000 ports support etherchannel
Answered Question
Mar 25th, 2010
I have requirement like below
                                             --------------Ethernet Point-to-Point Leased Line1------------------
--------Trunk-------- 2911 Router        2911 Router-------Trunk-------------
                                             --------------Ethernet Point-to-Point Leased Line2-------------------
I am planning to use existing onboard 3 10/100/1000 ports in 2911 router for one trunk and etherchannel configuration. Trunk connects to local lan and etherchannel conncts to remote branch. My doubt is can I configure 2911 onboard ports as trunk and implement etherchannel? As of now there will be no routing configuration in 2911.
Siva K
Correct Answer by Giuseppe Larosa about 7 years 1 month ago
Hello Siva,
use a LAN switch for this or an etherswitch module installed in the C2911 routers
routed ports can be used only as routed ports or for bridiging (IRB) you cannot configure them as L2 trunks, you may use them as a L3 port-channel but not as a L2 trunk port-channel.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Fri, 03/26/2010 - 06:54
  • Hall of Fame,
    Founding Member
Hello Siva,
Hope to help
Giuseppe
