CME 79XX Web Access Enabled = No
Answered Question
Mar 25th, 2010
How can I change the handset Web Access Enabled to YES with CME7.1 ?
Correct Answer by Aaron Harrison about 6 years 12 months ago
Good to hear..
Please help to identify useful content in the forums by marking questions as 'answered' if you have received a suitable response..
https://supportforums.cisco.com/docs/DOC-6212
Aaron
Overall Rating: 5 (8 ratings)
Aaron Harrison Fri, 03/26/2010 - 03:02
  • Community Spotlight Award,
    Member's Choice, May 2015
You can enable this for all phones like as follows (this will just insert the webAccess parameter into the vendor specific section of the XML config file the phones load as they boot - the webAccess bit will be case sensitive).
Telephony-service
Service phone webAccess 1
Create cnf-files
Then restart your phones...
Aaron
Please rate helpful posts...
Correct Answer
Aaron Harrison Mon, 03/29/2010 - 04:00
Good to hear..
Aaron
rmartin001 Tue, 11/02/2010 - 16:38
CME version 7.0.0
Had to change "service phone webAccess" value to "0" so = enable. "1" = disable.
Tested with "1" and it was disable on phones 7960 and 7962. Tried with latest firmware also (7960 at 8.1.2) (7962 at 9.0.2).
Rauf Mammadov Thu, 04/21/2016 - 04:50
I have CME versin 8.8, "service phone webAccess=0" command enabled Web Access, but 1 disables it.
