FTP over VPN on ASA V8.2.2
Mar 25th, 2010
Hi All,
I have upgrade my ASA from 8.0.4 to 8.2.2 and post that ftp data traffic going over the VPN terminating on the ASA is not working,  do i need to do any configuration change for this.
Jennifer Halim Fri, 03/26/2010 - 04:55
1) Was it working on version 8.0.4?
2) Do you have "inspect ftp" configured? and it's ftp running on default port?
3) I assume both end of the tunnel is ASA running version 8.2.2?
4) Can you share config from both end?
UCBNOCNPS Fri, 03/26/2010 - 09:43
Thanks for your response, below are the answers to your queries do let me know if that leads to some solution
yes, it was working
it is enabled, i tried disabling it also it didnt helped
No one of the tunnel is PIX v 6.x and other ASA v 8.2.2, the ASA was upgraded also i have reverted it to old image for now so i can simulate issue any more.
I am sorry but i cnt share the configs, as per security constraints but if you have some suggestions or areas to look at in config that would be really greatfull.
Guneet Singh Gulati
Kureli Sankar Fri, 03/26/2010 - 13:37
When it fails what do the logs show?
conf t
logging en
logging buffered debug
exit
sh logg | i x.x.x.x
where x.x.x.x is the ip address this being used to test ftp.
-KS
