Multi-site-to-site vpn with dynamic ip
Mar 25th, 2010
I have about 10 remote offices with dynamic IPs using IP phones. HQ with a static IP
all sites are able to communicate with the HQ but remote offices can't dial 3 or 4 digits extensions and reach other remote sites.
currently the HQ has 2800 and ASA5505 at remote sites.
is there any work around to have remote site initate a tunnel to other remote site and place phone call without having to change the Cisco2800.
would it be better if I configure the remote site as easy vpn server?
thank you so much for your help.
Jonn cos Fri, 03/26/2010 - 03:57
Dear Hasaballa,
As far as the issue of dynamic IP is concerned it can be solved. You can use dynamic crypto map in here.
