ASA & SSH-Timeout
Answered Question
Mar 25th, 2010
I try to configure my ASA (ASA5520) to have an SSH timeout of 48 hours.
This is the config I use to realize that:
class-map CLASS_MAP_ANY
match any
class-map CLASS_MAP_SSH
match port tcp eq ssh
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect sqlnet
  inspect sunrpc
  inspect xdmcp
  inspect netbios
  inspect tftp
  inspect icmp
  inspect icmp error
  inspect dns
  inspect ip-options
class CLASS_MAP_ANY
  set connection random-sequence-number disable
  set connection decrement-ttl
class CLASS_MAP_SSH
  set connection timeout idle 48:00:00 reset
service-policy global_policy global
With this configuration every SSH connection throught the ASA drops afer exactly 2 hours. (Although the default was 1h).
Does anybody hav a hint for me?
Patrik
Correct Answer by Jennifer Halim about 6 years 12 months ago
Apology, absolute timeout is only for connection with uauth, currently not supported on normal connection.
Can you please move the sequence of your class-map where the CLASS_MAP_SSH class is above CLASS_MAP_ANY class as follows:
  inspect ftp
   inspect h323 h225
  inspect h323 ras
  inspect rsh
   inspect rtsp
  inspect sqlnet
  inspect sunrpc
  inspect  xdmcp
  inspect netbios
  inspect tftp
  inspect icmp
   inspect icmp error
  inspect dns
  inspect ip-options
class CLASS_MAP_SSH
class  CLASS_MAP_ANY
Overall Rating: 5 (1 ratings)
Jennifer Halim Fri, 03/26/2010 - 03:41
  • Cisco Employee,
How is the SSH Client and server connected? Directly off the ASA? or could it be other network device which is set with the absolute TCP timeout of 2 hours, hence the timeout occur? Are they the same SSH server that the client is trying to access? Maybe the SSH server is configured for maximum of 2 hours connection.
The configuration that you have is setting the idle timeout to be 48 hours, not absolute timeout of 48 hours.
patrik.spiess Fri, 03/26/2010 - 04:18
The client-network is directly connected.
The server is on the outside interface of the ASA. There are some other routers and switches between, but they seem not to be the problem. If I connect the client to the network which is outside the ASA the timeout does not occur. Even if the same outside routers and switches are between. This let me assume that the timeout occurs on the ASA an not on any other internediate system, and also not on the server.
So, any other ideas?
btw. : what do I the 'absolute timeout' need for and where do I configure that?
Correct Answer
Jennifer Halim Fri, 03/26/2010 - 04:46
  • Cisco Employee,
  inspect ftp
   inspect h323 h225
  inspect h323 ras
  inspect rsh
   inspect rtsp
  inspect sqlnet
  inspect sunrpc
  inspect  xdmcp
  inspect netbios
  inspect tftp
  inspect icmp
   inspect icmp error
  inspect dns
  inspect ip-options
class CLASS_MAP_SSH
class  CLASS_MAP_ANY
patrik.spiess Mon, 03/29/2010 - 01:30
Thanks to halijenn
This was it. Now my ssh connection works longer than 2 hours.
Great !
