ErrDisable at SFP Interface between C3750 with C3560
Answered Question
Requirement: connecting 2 lan switches with SFP cable.
The LAN Switches to be connected are: C3560-24TS+2SFP with C3750-24TS+2SFP
Cable SFP: CAB-SFP-50CM-cable
when the installation is done, the error show up in the SFP interface, as below:
Port      Name               Status       Vlan       Duplex  Speed Type
Gi1/0/1                      err-disabled 1            auto   auto unknown
Test_Switch#sh interfaces status err-disabled
suspected err is from the cable, which is not working for both lan switch.
Port      Name               Status       Reason
Gi1/0/1                      err-disabled gbic-invalid
Question: what type of cabling is suitable/compatible to be used for connecting 2 different types of lan switches?
Run the errdisable recovery but not help much.
Thanks in advance.
Hira
Correct Answer by Aaron Harrison about 7 years 2 months ago
As I understand it, you can only use that cable with 3560s:
http://www9.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00800a7af7.shtml#patch-cable
Quote 'The Catalyst 3560 switch supports the SFP module patch cable, a 1/2 meter, copper, passive cable with SFP module connectors at each end. The patch cable can connect two Catalyst 3560 switches in a cascaded configuration. '
Or https://supportforums.cisco.com/docs/DOC-1515/diff;jsessionid=0C72B9E367B58777F2C7AF045001E637.node0?secondVersionNumber=3
Aaron
Please rate helpful posts...
Overall Rating: 5 (1 ratings)
Correct Answer
Aaron Harrison Fri, 03/26/2010 - 04:43
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
Yap, you are correct. that cable can be only used for 3560s.
I want to order below SFP for connecting the C3560 with C3750:
Cisco Gigabit Ethernet SFP: Cisco 1000BASE-T SFP
Part Number: GLC-T SFP-GET3
Description: 1000BASE-T SFP Transceiver Module for Category 5 copper wire.
is that a correct SFP type?
Thanks again
Hira
Leo Laohoo Sun, 03/28/2010 - 21:05
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
GBIC-invalid would probably means that you have a non-Cisco SFP.
