IP Phones frequently reboot
IP Phones frequently reboot. this is not confined to particular phones, it is random. i have tokyo and singapore phones registered to callmanager. callmanager is at singapore. i do not see problem with phones at tokyo. can u suggest what would be the problem facing Singapore phones
Callmanager used 4.1
Madhusudhan Rao M
8 Replies 8
Jaime Valencia
Look at the reason code for the unregister event in the application log as initial step.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
am trying to get the callmanager access. i.e., RDP to check the log messages. even RTMT is not showing the messages. But do you have an idea on what would be the problem, since i can rule out callmaneger problem since i have remote phones registered to it. i do not see any problem with their operation
Well - if you are certain that the phones on both sites are using the same CallManager server (it's possible you have two, and one site may be using the second for service).. and you definitely have no issues on the remote site... then there is likely a network issue of some sort on the problem site.
Can you describe your network topology? Do you have your CCM servers in a separate subnet to the IP Phones?
You do really need to start with getting access to the server to check the event logs as Java suggested...
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Phones are in a different subnet than callmanager. will port fast configured on the access port cause any issue
No, port fast is usually a good thing.
I suspect something in the client IP phone VLAN is unstable... can you try running this command on your IP phone switch:
Show spanning-tree vlan X active
Where X is your IP phone VLAN...
Aaron
hi,
this is the output from one of my access switch, i think there is a problem with edge p2p  as the output
Interface        Role Sts Cost      Prio.Nbr Type
Fa0/1            Desg FWD 19        128.1    Edge P2p
Fa0/2            Desg FWD 19        128.2    P2p
Fa0/5            Desg FWD 19        128.5    Edge P2p
Fa0/8            Desg FWD 19        128.8    Edge P2p
Fa0/11           Desg FWD 19        128.11   Edge P2p
Fa0/12           Desg FWD 19        128.12   Edge P2p
Fa0/13           Desg FWD 19        128.13   P2p
Fa0/14           Desg FWD 19        128.14   Edge P2p
Fa0/16           Desg FWD 19        128.16   P2p
Fa0/17           Desg FWD 19        128.17   Edge P2p
Fa0/18           Desg FWD 19        128.18   Edge P2p
found the solution..one of the desktop was assi
gned a Voice Vlan subnet ip which caused the problem
it has been stable since then
