What and when happens if the units remaining goes below zero in "License Unit Report" in Cisco Unified CM Administration System version: 7.0.1.11000-2?
Answered Question
Mar 26th, 2010
In our "Cisco Unified CM Adminstration System version: 7.0.1.11000-2", I have notied that the "Units Remaining" is -191 in the "License Unit Report" ("System" => "Licensing" => "License Unit Report")
I have attached a screendump of the number.
What will happen if the number gets to small and when does someting happens?
Kind regards,
Carl-Marius
Correct Answer by Aaron Harrison about 7 years 2 months ago
I believe it's written in your license files as per this document:
http://ciscosystems.com/en/US/docs/voice_ip_comm/cucmbe/admin/7_1_2/ccms...
Aaron
Nothing - you'll just reach a point where it no longer allows you to add new devices.
You are allowed an 'overdraft' of a certain percentage to allow you time to obtain the licenses you need.
Aaron
Please rate helpful posts...
Overall Rating: 5 (2 ratings)
Correct Answer
Aaron Harrison Fri, 03/26/2010 - 02:02
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
Carl-Marius.Steensen Fri, 03/26/2010 - 03:56
Hi Aaron,
As always, a fast and very helpful answer, thank you!
Do you know the size of this percentage? (Just so I know when I need to request more licenses).
Kind regards,
Carl-Marius
