Cisco 3750E 10G SFP+ to HP NC522SFP+ DAC
Mar 26th, 2010
I am looking at using the following equipment
Cisco 3750E switch with X2 to SFP+ Adapter connected using a HP SFP+ direct twinax type cable 7m  to a HP NC522SFP+ NIC
I have enabled the cisco command to allow the non Cisco SFP+ cable to be used ( as the HP card I understand can only use a HP cable - not Cisco) but I cant get them to connect
Does anyone else have this working?
Overall Rating: 4 (1 ratings)
Sergey Glazunov Mon, 09/06/2010 - 00:54
Hello, Michael.
Do you know the answer to your question? I have the same problem, and I don't know how to make it work. Could you help me?
mhutchesson Mon, 09/06/2010 - 01:37
In the end I went and purchased the Cisco 5m SFP cable, it seems to work.
rcsu-it Wed, 12/01/2010 - 08:20
Would you be able to list the part numbers you are referring to?
mhutchesson Thu, 12/02/2010 - 04:38
The cable that works for me is
SFP-H10GB-CU5M=10GBASE-CU SFP+ Cable 5 Meter
