CCNA Expired - Options for CCVP?
Answered Question
Mar 26th, 2010
Hi All,
My CCNA has got expired one year ago. Right now I am pursuing CCVP track and completed CIPT1 recently.
My doubt is - Is it valid to write CCNA *AFTER* passing CVOICE? Will it be considered as CCNA Voice and considered as prerequisite for CCVP?
My exact plan is as follows:
1. CIPT1 (completed)
2. CVOICE
3. CIPT2
4. TUC
5. CCNA
6. QoS
(Going to take exams in the above order)
Is this a valid way/path for CCVP? Will I be give CCNAVoice and CCVP certificates if I do like this?
Correct Answer by Brandon Buffin about 6 years 11 months ago
Yes, as long as the exams are all completed within a 3 year period, you will receive CCNA Voice and CCVP. Each individual exam expires after 3 years.
Hope this helps.
Brandon
Overall Rating: 5 (1 ratings)
Correct Answer
Brandon Buffin Fri, 03/26/2010 - 07:20
Hope this helps.
Brandon
Johns George Fri, 03/26/2010 - 22:26
Hi Brandon,
Thanks a ton for the reply/information. It really helps. I was in a big confusion. Now I can move on.
Will write to you again in case of any question.
Thanks again,
Johns.
sharish82 Mon, 05/24/2010 - 02:58
Hi Brandon,
Pl let me know if there is some rule like we have to complete the 5 ccvp papers in a year to get ccvp certification.
S.Harish.
Walter Solano Mon, 05/24/2010 - 05:12
There are no formal rules or order to complete the CCVP exams, you can do those in any order as long as make the 5 exams within 3 years and you have a valid CCNA voice because its a prerequisite for this certification.
For example this is the path that I am taking:
1.Cvoice
2.CIPT I
3.CIPT II
4.QoS
5.TUC --Will do it next month
Please rate this post if was helpful
Walter Solano
CCNA Voice
Cisco UCCX Specialist
lalit@_78 Thu, 12/16/2010 - 02:46
Hi Brandon,
If i can give all the CCVP papers first and finally CCNA will i will be eligible to receive CCVP Certification or Should i complete CCNA papers before finishing CCVP Papers.
Example  :  CIPT1 , CIPT2 , CVOICE , TUC , QOS and finally CCNA.Will this be a valid way.
Whether i should complete CCNA first before i finish CCVP papers ?
Please let me know.
Lalit
Brandon Buffin Thu, 12/16/2010 - 05:17
Lalit,
     You can do the exams in any order you would like as long as you complete them within 3 years of passing the first exam.
Hope this helps.
Brandon
