NAT and ASA 5505
Mar 26th, 2010
Hi, I tring to pass from 192.168.202.77 (VLAN1) to web interface 192.168.20.12(VLAN4)
Here is a configuration
interface Vlan1
nameif inside
security-level 100
ip address 192.168.202.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address ***.***.***.*** 255.255.255.248
interface Vlan3
nameif dmz
security-level 50
no ip address
interface Vlan4
nameif wi-fi
security-level 60
ip address 192.168.20.1 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
switchport access vlan 3
interface Ethernet0/4
switchport access vlan 4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
access-list inside_access_in extended permit tcp host 192.168.202.77 host 192.168.20.12
access-list wi-fi extended permit tcp host 192.168.20.12 host 192.168.202.77
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
access-group wi-fi in interface wi-fi
static (inside,wi-fi) 192.168.20.12 192.168.202.77 netmask 255.255.255.255
static (wi-fi,inside) 192.168.202.77 192.168.20.12 netmask 255.255.255.255
Tell me please, what is the problem?
Jithesh K Joy Fri, 03/26/2010 - 08:03
HI,
   If you want to access 192.168.20.12 from  192.168.202.77   the static identity  NAT can be used  instead of the present static NAt config
static (inside,wi-fi) 192.168.202.77  192.168.202.77 netmask 255.255.255.255
static (wi-fi,inside) 192.168.20.12  192.168.20.12 netmask 255.255.255.255
Joy
Jennifer Halim Fri, 03/26/2010 - 15:20
  • Cisco Employee,
These lines are incorrect statements:
Please remove the above statement, and configure the following:
Please perform "clear xlate" after configuring the above.
If you are testing by ping, you might want to check if "inspect icmp" has been turned on.
Hope that helps.
Jithesh K Joy Mon, 03/29/2010 - 07:23
Hi halijenn,
  Destination NAT
static (wi-fi,inside) 192.168.20.12  192.168.20.12 netmask 255.255.255.255 is required to reach  192.168.20.12  ?
Jithesh
Kureli Sankar Mon, 03/29/2010 - 08:01
  • Cisco Employee,
No. Just this line
is good enough.  This is bi-directional.  With this line inside host 192.168.202.77 can initiate connection to anyone in the wi-fi interface and wi-fi can initiate connection to 192.168.202.77 provided the acl applied on the wi-fi interface allows it.
-KS
Lunzhicheng7 Mon, 03/29/2010 - 20:07
Hi , there
Firstly, it seems such configuration “static (wi-fi,inside) 192.168.202.77 192.168.20.12 netmask 255.255.255.255” is unnecessary.
Secondly, you need to add an access-list permit the traffic which destination direct to your Nated address 192.168.20.12
For example : ” access-list out permit tcp any host 192.168.20.12”
I hope my suggestion is helpful
Fox Mulder
