Question about port security 2
Answered Question
Mar 26th, 2010
I do some practice with switchport security.I activated sticky security on swich ports and did
violation-shutdown. The problem is now that i can not find how to acitvate them again without
reseting my switch. The command "no shutdown" in interface for, lets say, fa0/1 just simple do
nothing.  After violation i tried to do: "interface fa0/1 shut" and then "no shut" - it tries
to activate but after couple of seconds it shows violation again. How to switch off the
"violation" ?
Many thanks
Correct Answer by Collin Clark about 6 years 10 months ago
Is the port learning a new MAC on the interface? Post your interface config please.
Overall Rating: 5 (1 ratings)
Correct Answer
Collin Clark Fri, 03/26/2010 - 06:43
tadasbalnys Fri, 03/26/2010 - 06:47
I just learned: " no switchport port-security"
and then
"int fa0/1 no shut".
Thank you for your quick respond.
