neighbor eigrp
Mar 26th, 2010
In a lan with several routers with interfaces in the same networks, is it possible to make that only ones are neighbors an others not?
This is an example:
routerA
router eigrp 200
network 10.0.0.0
no auto-summary
Router B
router eigrp 200
network 10.0.0.0
no auto-summary
Router C
router eigrp 200
network 10.0.0.0
no auto-summary
I wanto to only RouterA and Router B are neighbors eigrp
Marcelo
MARCELO MATURO Fri, 03/26/2010 - 07:20
passive- interface is no an option y my real situation. Filtering maybe a solution.
There is the option to convert the peering to unicast ( neighbor x.x.x.x interface x), but i don´t know that if this command stop all the multicast or only the network involved.
Marcelo
Giuseppe Larosa Fri, 03/26/2010 - 07:18
  • Hall of Fame,
    Founding Member
Hello Marcelo,
in addition to using passive-interface, you could use EIGRP authentication with matching parameters only on devices that should be neighbors
see
http://www.cisco.com/en/US/docs/ios/iproute_eigrp/configuration/guide/ire_cfg_eigrp_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1062735
Hope to help
Giuseppe
Tharak Abraham Fri, 03/26/2010 - 07:19
  • Bronze, 100 points or more
Marcelo,
Eigrp message authentication might help ya !
(config)#key chain KEY
(config)#key 1
(config)#key-string crack
(config)#interface eth0
(config-subif)#ip authentication mode eigrp 10 md5
(config-subif)#ip authentication key-chain eigrp 10 KEY
