Config Cisco ASA without interaction
Mar 26th, 2010
I'm looking for a way to update and configure an Cisco ASA without serial connection.
I can only use an network connection.
I was wondering what my options would be.
Kind regards,
Collin Clark Fri, 03/26/2010 - 07:12
You can use the web-based ASDM, ssh, and/or telnet. The initial configuration will require a serial connection, no way around that.
Hope it helps.
