VLAN L3 routing on router or switch ?
Answered Question
Mar 26th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Anyone knows the differences to put the VLAN L3 on the Router’s Ethernet port or a switch with L# capabilities ?.
Thank you.
Correct Answer by Reza Sharifi about 7 years 1 month ago
Hi Luis,
On the switch you would need to create an SVI and the IP to it.  On the router you would need to create a sub-interface and the IP to it.
Reza
Overall Rating: 4.5 (2 ratings)
Correct Answer
Reza Sharifi Fri, 03/26/2010 - 08:27
  • Cisco Designated VIP,
    2017 LAN
Hi Luis,
Reza
Jon Marshall Fri, 03/26/2010 - 08:36
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
lveraza2010 wrote:
The performance is the same ?.
No it isn't because a L3 switch routes packets in hardware and a router routes packet in software so with a L3 switch and a router costing roughly the same the L3 switch will vastly outperform the router.
Jon
milan.kulik Fri, 03/26/2010 - 09:24
  • Red, 2250 points or more
On the other hand, L3 switches usually don't provide all advanced routing features (NAT, e.g.).
BR,
Milan
robmccam1 Sat, 03/27/2010 - 08:07
The two technologies grew together.  The router however tends to offer more WAN interface solutions (WIC) than the L3 switch.  There is also the advantage of the logical abstraction that the router provides over the L3 switch.
ucsd92126 Wed, 03/31/2010 - 14:40
What about firewall ASA and L3 switch?  I plan to add a new VLAN but not sure where to put the routing.
Reza Sharifi Wed, 03/31/2010 - 15:25
    2017 LAN
Hi Nelson,
If your switch is a layer-3 switch then add the svi for the new vlan on the switch.
Reza
