Copy disk0: content to standby ASA
Mar 26th, 2010
I'm hoping that I'm just missing something obvious....
I've got a pair of ASA 5520s in failover mode (active/standby).  I've install the AnyConnect client on the flash in the Active 5520.  How do I copy the client from disk0: on the acti
Panos Kampanakis Fri, 03/26/2010 - 14:25
  • Cisco Employee,
Not sure if I misunderstood your question. You can copy the image to the standby using tftp.
PK
patrick.peters Mon, 03/29/2010 - 10:52
I should clarify the question a little bit...
In my ASA pair, the management interfaces (where they keep track of each other for failover) are connected via a crossover cable.  There is no connectivity except to each other.  It seemed like the right thing to do at the time--no other communication would interfere with the 2 ASA's discussing their state.  So, the passive ASA has all of its interfaces down except for the management interface, which has no connectivity other than to its partner ASA.
I was hoping there was some sort of a "copy from my flash to my partner's flash" command...
Pat
Panos Kampanakis Mon, 03/29/2010 - 15:25
  • Cisco Employee,
I see.
Unfortunately you cannot have the primary ASA serve as a tftp or ftp server. But I believe you can sue https. You can get the image from the ASA that has it using url https://ASA_IP/disk0/filename
So you probably can download the image on the secondary using http for that path using
copy
http[s]://[user[:password]@]server[:port][/path]/filename {flash:/ | disk0:/ | disk1:/}[path/]filename
as explained here http://www.ciscosystems.li/en/US/docs/security/asa/asa82/configuration/guide/admin_swconfig.html
I hope it helps.
PK
Related Content
