Contact Centre Express 7 admin user not authenticating after LDAP Server removed and readded
Answered Question
Mar 26th, 2010
We had to delete and re-add our LDAP Server (and users) and now our craadministrator is unauthorized.
Is there a way of resetting or reactivating the user?
CUCCX 7.0(1) (two node cluster), CUCCM 7.1.3
Thanks in advance,
John
Correct Answer by Anthony Holloway about 7 years 1 month ago
You probably just don't know what it's called, but you need to re-run the initial setup wizard so you can choose a new administrator.
There are many posts on this topic:
http://www.google.com/search?sourceid=chrome&ie=UTF-8&q="FRESH_INSTALL"+site:cisco.com
I will just tell you now, some of these posts say to restart the node manager after you change to "FRESH_INSTALL", and that is not required.
Post back if you run in to issues.
Overall Rating: 5 (1 ratings)
Correct Answer
Anthony Holloway Fri, 03/26/2010 - 12:05
  • Purple, 4500 points or more
Anthony Holloway Mon, 03/29/2010 - 07:32
You're welcome.  Glad we could get it figured out for you.
Aaron Harrison Fri, 03/26/2010 - 12:09
  • Community Spotlight Award,
    Member's Choice, May 2015
You've removed and re-added it in CCM, so that's where you need to start troubleshooting.
Check whether the account appears in CCMAdmin (End Users). See if it is listed as 'Active'...
Aaron
