03-26-2010 12:38 PM
"You don't have permission to access /cwhp/LiaisonServlet on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request."
I get this screen when I try to conect to CW.
I attach others files that can be useful.
Thanks very much in advance!!
03-26-2010 10:56 PM
This pdshow looks bad. You're missing the Apache daemon. Post the full output of the pdshow command (without the -brief flag). Also, post a screenshot of your Services control panel showing all of the CiscoWorks services. Also, post the output of "pdreg -l Apache".
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
03-29-2010 08:09 AM
Hi Joe!
Here attach the complete pdshow, and the services status.
The output "pdreg -l Apache":
>pdreg -| apache
[Mon Mar 29 11:03:38 2010] [warn] pid file c:/program files/cscopx/mdc/apache/logs/httpd.pid overwritten -- Unclean
Apache running...
I don´t know if a have to wait to complete run the Apache for view the output
Thanks in advance!!
best regards!!
03-29-2010 08:13 AM
03-29-2010 08:53 PM
The command is:
pdreg -l Apache
That is "dash ell" not "dash pipe".
03-29-2010 08:56 PM
Your installation appears to be damaged. You're missing the Apache daemon. This is critical. You also have some service parameters set incorrectly. The only service which should be Automatic is Daemon Manager (and tftp, rsh, and syslog). The other CiscoWorks services must be Manual. But, even after fixing that, the Apache daemon is gone. What was done on this server recently?
03-30-2010 08:45 AM
I do the command with and without capital letter at beginning and get this error:
C:\Documents and Settings\ecortez>pdreg -l Apache
ERROR: Apache is not a registered server name.Please enter a valid process/serve
r name or check the case of the entered process/server name.
C:\Documents and Settings\ecortez>pdreg -l apache
ERROR: apache is not a registered server name.Please enter a valid process/serve
What have to do now? I must change the services all in Manual except the Daemon Manager?
With the server we do not do nothing, just install the 3.2 LMS version..
thanks very much in advance!!
best regards!!
03-30-2010 09:36 AM
Then it sounds like the upgrade failed. I suggest you uninstall LMS, then reinstall 3.2 from scratch. When it is installed, restore a data backup from 3.1.
03-30-2010 01:12 PM
Sorry, I say wrong: was not an update to LMS3.2, is a CWLMS 3.1, and the installation was without problem.
I changed the process to automatic, except the Daemon Manager.
Why the Apache daemon is missing?
I think that is a problem of authentication, because else not display this kind of error:
Please, tell me if I can modify the permissions of causer or admin user.
03-30-2010 10:00 PM
I don't know why the Apache daemon is gone. This would point to some kind of Registry issue if you did not make any conscious changes. The only way to recover safely at this point is to reinstall LMS as I described. Reinstall 3.1, then restore a known good data backup.
The reason you see the error is that Apache is not being started by Daemon Manager. It is still installed on the system, but somehow, it was unregistered from Daemon Manager. This isn't a problem we typically see which is why I'm recommending such a drastic solution to correct it.
