CUCM 7.1 - Need to bulk associate CUPC Line/DN with Username
Answered Question
Mar 26th, 2010
Does anyone know of a way to bulk associate CUPC directory numbers with their usernames?  Right now I have to go one by one and update them manually.
The manual process is as follows;
  1. Go to the UPC Device
  2. Go into the directory number that I want to associate with CUPC
  3. Click "Associate Users"
  4. Search for username, click save.
If there was a way to bulk associate a directory number within the UPC device to a username, that would save a lot of time.
If anyone knows how, please share!
Thanks in advance!
Correct Answer by tbergquist about 7 years 2 months ago
Brian,
The below posting was submitted by another CCO user "htlup"  I am simply re-posting it as It was helpful for me and it works great.
For Line Association,You will need to make a file with the following format:
User ID,Device,Directory Number,Partition
Then, upload it using the BAT file upload tool and select BAT -> Users -> Line Appearance -> Update Line Appearance. Select your file and for CUPC users only. This populates the 'Users Associated with Line' field under the line on the phone.
Correct Answer by htluo about 7 years 2 months ago
You may go to CUCM > Bulk Administration > Users > Line Appearance > Update Line Appearance.
Click "View Sample File" to see the example.
Michael
http://htluo.blogspot.com
Overall Rating: 5 (6 ratings)
Correct Answer
htluo Fri, 03/26/2010 - 13:04
  • Red, 2250 points or more
Michael
Brian Carlson Fri, 03/26/2010 - 13:08
Michael,
Thanks for your help, that was exactly what I was looking for!
Correct Answer
tbergquist Fri, 03/26/2010 - 13:09
Brian,
Brian Carlson Fri, 03/26/2010 - 13:11
tbergquist,
Thanks for your help.  This forum is truly an excellent resource!
tbergquist Fri, 03/26/2010 - 13:12
Looks like everyone beat me to it!  Yes.  I use the forums almost everyday!
htluo Fri, 03/26/2010 - 13:16
Ya, I guess some people (not me) wrote a script to auto-answer those qustions.
Michael
vinhnguyen Tue, 06/29/2010 - 22:58
Do you know what to put in the DEVICE column if I have device profile rather than a physical mac address.  I tried with the device profile name but keep getting an error
"bad device name"
