Web VPN - Rdp plugin and accessing internal website - ASA 5510
Mar 26th, 2010
I am trying to use WebVpn to do the following:-
1. Remote Desktop - How do I get the printers my users have on their local machines mapped across so they can be used in the Remote Desktop. By connecting using th eCisco VPN Client it works, so there must be a way of getting it to work withthe RDP plugin.
2. Allow users to access the internal network website, hosted at http://192.168.0.2:5108
3. Allow users to use Outlook to open a Pop3 session to collect mail.
I think 1 and 2 are possbile using Web VPN - but cannot fathom out how to do it!
I think 3 is not possbile - but could someonw confirm how I should proceed!
trippi Fri, 04/02/2010 - 10:59
You can't map printers with the RDP Plugin.
You can use the Anyconnect client and then use an onconnect script to achieve this.
You should be able to do the URL by placing a link on the portal page to it and you have your NAT setup correctly between the VPN pool addresses and that server.
You will need to configure a smart tunnel for the outlook pop3 access.
http://www.cisco.com/en/US/products/ps6120/products_installation_and_configuration_guides_list.html
