1524 Powering On
Mar 26th, 2010
Have a 1524 that will be used as a MAP and will connect to 1 RAP.  Just the 2 APs on the controller.  The RAP powers on fine but the one that I am using as a MAP will not power on unless I hook a computer to it to or into my network.  It will only power on if it has a wired network connection?  I am hooking 2 cameras to the MAP and shooting that back to my RAP.  How do I power it on?
