Difference between LAN Base, IP Base, and Enterprise IOS
Mar 26th, 2010
Can you give light on this?
What are differnces between these three IOS'? I have read differences between IP Base and Ent. IOS. Does LAN Base IOS 4500-E switch doesn't Layer 3 routing capability?
Overall Rating: 5 (1 ratings)
Lei Tian Fri, 03/26/2010 - 21:20
  • Cisco Employee,
You can think LAN base is subset of IP Base, and IP Base is subset of Enterprise. LAN base is L2 only; IP Base supports basic L3 function; enterprise supports all L3 functions.
HTH,
Lei Tian
praetoleiad Fri, 03/26/2010 - 21:27
Thank you sir for the prompt response to the query. Now it's been clear to me.
