Removing login for personal directory?
Mar 27th, 2010
Is there any way to make it so that users do not have to enter there userid and pin when accessing their personal directory from their phone?
Seth
Aaron Harrison Sat, 03/27/2010 - 05:21
  • Community Spotlight Award,
    Member's Choice, May 2015
Possibly - what version of CCM do you have?
For 6.x - set up a new Personal Directory service as :
http://servername-or-ipaddr:8080/ccmpd/login.do?name=#DEVICENAME#&servic...
Parameters:
userid
pin
Set pin as a password field.
When you subscribe it to the user, either put in their userid and pin for them, or have them enter the userid/pin in ccmuser.
If you are on 4.x there are a few docs around that detail what you need to do...
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note0...
Aaron
Please rate helpful posts...
srosenthal Sun, 03/28/2010 - 07:25
I am running version 7.1.
I will give it a try.  It seems like what your saying is that this would have to be done for each users individually versus a system wide setting that would allow people to access the personal directory of a phone without having to log in to the phone.
Seth
Aaron Harrison Sun, 03/28/2010 - 10:17
Yes, that's it. It always requires authentication, but you can insert the auth into the service subscription params.
Aaron
