DMM 5.1 - 404 HTTP Error
Mar 27th, 2010
I am trying to connect to DMM5.1 admin page for the first time and yet getting a 404 error. I am sure I can ping the hostname of the DMM and it matches the same one configure on DMM applicance. I am using the URL  http://<DMM Hostname>:8080 and no luck. I am getting the following error:
Any ideas?
HTTP Status 404 - /dmsadmin/main.jsp
type Status report
message /dmsadmin/main.jsp
description The requested resource (/dmsadmin/main.jsp) is not available.
Tomas De Leon Mon, 04/05/2010 - 08:27
  • Cisco Employee,
Sorry for the delay,
  • Please access the DMM and Verify the Server settings (IP & FQDN)
  • One of the Services may be down or not initiated.  Please reboot DMM.
  • After the DMM has restarted, Try to access the DMM again
  • Please provide the entire URL and error message snapshot if the problem continues.
  • Also, provide a snapshot of the SHOW INFO screen from the AAI interface
T.
jwitul Sat, 06/19/2010 - 07:30
  • Cisco Employee,
Glad to see someone else is having this issue.  I've used VMs of the demo 5.1 without a problem, and on several different machines.  Now I'm trying to set up a server from scratch and get the same issue as the previous post.
I know my DNS is working, I can ping the hostname of the server fine, and I can access another DMM that is running as a VM fine, but not this machine.  I have restarted everything and flushed DNS on the computer I am trying to use to http to the DMM (when I had the same IP address for one physical and one virtual DMM, and tried to disconnect one and switch between the two).
I have reloaded a new ISO, one I downloaded and one was downloaded by a coworker, and both do exactly the same thing.  My next step will be to try to download and run the 5.2 ISO.  If that doesn't work, I don't know what to do.
