Configure WIC-1ADSL
Mar 27th, 2010
Hello people!
I'm Sao Paulo - Brazil and here my ISP Telefonica work with RFC 2864. I need configure my interface WIC-1ADSL with following IPs.
It is easy part.
Fixed IP = 189.19.35.xxx
Gateway = 189.19.35.yyy
Mask = 255.255.255.0
Here it's my question. How to configure its on WIC-1ADSL? It's possible or I need another interface which work with encapsulation?
WAN = 172.20.7.170
Gateway = 172.20.7.169
Mask = 255.255.255.252
On my modem SpeedTouch I have a same configuration.
1 > software version
2 > env list
3 > env set var SESSIONTIMEOUT value 0
4 > ppp flush
5 > pptp flush
6 > eth flush
7 > eth bridge flush
8 > atm flush
9 > atm phonebook flush
10 > script flush
11 > ip ipdelete addr=10.0.0.138
12 > dns server config state disabled
13 > saveall
14 > env set var=CONF_SERVICE value=IP_FIXO_Metro_IPoE
15 > atm phonebook add name=pvc addr=8*35
16 > atm ifadd intf=atm
17 > atm ifconfig intf=atm dest=pvc ulp=mac
18 > atm ifattach intf=atm
19 > eth ifadd intf=ethoa
20 > eth ifconfig intf=ethoa dest=atm
21 > eth ifattach intf=ethoa
22 > ip ifadd intf=ipoe dest=ethoa
23 > ip ifconfig intf=ipoe status=up
24 > ip ifattach intf=ipoe
25 > ip ipadd intf=ipoe addr=172.20.9.170/255.255.255.252 addroute=enabled
26 > ip rtadd dst=0.0.0.0/0 gateway=172.20.9.169
27 > ip ipadd intf=LocalNetwork addr=$$$.$$$.$$$.$$$/255.255.255.0 addroute=enabled
28 > dhcp server flush
29 > dhcp server pool add name=ipfixo
My traceroute.
traceroute 189.19.35.xxx
traceroute to 189.19.35.xxx (189.19.35.xxx), 30 hops max, 60 byte packets
1 * * *
2 201-0-93-137.dsl.telesp.net.br (201.0.93.137) 28.573 ms 30.709 ms 31.883 ms
3 201-0-5-149.dsl.telesp.net.br (201.0.5.149) 34.056 ms 201-0-5-153.dsl.telesp.net.br (201.0.5.153) 35.718 ms 201-0-5-149.dsl.telesp.net.br (201.0.5.149) 37.388 ms
4 201-63-253-73.customer.tdatabrasil.net.br (201.63.253.73) 39.558 ms 41.215 ms 42.895 ms
5 200-100-1-246.dsl.telesp.net.br (200.100.1.246) 44.755 ms 200-100-1-250.dsl.telesp.net.br (200.100.1.250) 45.875 ms 200-100-1-242.dsl.telesp.net.br (200.100.1.242) 48.079 ms
6 * * *
7 172.20.7.170 (172.20.7.170) 107.368 ms 102.621 ms 98.416 ms
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
Thank you for help.
Best regards.
Giuseppe Larosa Sun, 03/28/2010 - 23:41
  • Hall of Fame,
    Founding Member
Hello Antonio,
my guess is that your provider may be using RFC 1483 bridged where
IP/ethernet/AAL5 is carried over the ADSL line.
That it is different from an RFC 1483 routed where you have:
IP/AAL5 over ADSL line
refer to this document and look at the configuration part customer side = CPE
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a0080093e5f.shtml
Hope to help
Giuseppe
DialerString_2 Mon, 03/29/2010 - 12:39
  • Bronze, 100 points or more
Let me know if you need a sample bridging config -  I have multiple sites set up for it.
Antonio Carlos ... Tue, 03/30/2010 - 05:39
Hello!
If you can. I'll be very happy.
I'm fighting with this inteface.
Thank you very much.
Manish Kumar Mon, 03/29/2010 - 16:00
  • Cisco Employee,
Sample config for your quick reference:
PPPoEoA Sample Configuration:
vpdn enable
no vpdn logging
vpdn-group 1
request-dialin
  protocol pppoe
interface Ethernet0
ip address 192.168.100.1 255.255.255.0
ip tcp adjust-mss 1452
ip nat inside
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 8/35
  pppoe-client dial-pool-number 1
dsl operating-mode auto
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp chap hostname <>
ppp chap password 0 <>
ppp pap sent-username <> password 0 <>
ip nat inside source list 101 interface Dialer1 overload
ip route 0.0.0.0.0.0.0.0 Dialer1
access-list 101 permit ip 192.168.100.0.0.0.0.255 any
