03-28-2010 01:57 AM - edited 03-06-2019 10:20 AM
i am trying to configure NAT with overloading option.
we have 16 static IP from the ISP, we use most of them as static nating for our servers.
we need to use one or 2 static IP addresses for all the users to connect to the internet (NAT + overload).
i have looked it up to configure it, we can use this commant to do it:
ip nat inside source list -access-list name- pool -pool name- overload
i have 2 questions now if i may ask:
- am i in the right direction? or i am totaly lost
-how can i define a pool of addresses? can i assign the addresses i need?
thank you for your support
Solved! Go to Solution.
03-28-2010 02:25 AM
Yes this is the correct way to do it.
To define the pool -
ip nat pool NPL 195.20.1.10 195.20.1.11 netmask 255.255.255.248
Jon
Cisco are currently donating money to the Haiti earthquake appeal for every rating so please consider rating all helpful posts.
03-28-2010 02:25 AM
Jon
03-29-2010 06:28 AM
thanks alot, it works just fine now
03-28-2010 10:53 PM
Yes you are on the right way,just check out the below link for step by step configuration of NAtting in routers.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml
Hope to Help !!
Remember to rate the helpful post
Ganesh.H
03-29-2010 06:31 AM
thanks, appreciated.
