Cistomized privilege level with ACS 5.1
Mar 28th, 2010
Hi All, any one  has done the implementation of command authorization with ACS.
I want to create a command set in which user can only run show command which i specified and some command in configuration mode like assigning vlans to switch ports.
I have ACS5.1.0.44. what I will have to configure on switches and what on ACS ?. It should be a customised privilege level kind of.
Javier Henderson Mon, 03/29/2010 - 08:40
On the switch, enable command authorization.
On ACS, create a command set and apply it to an access policy.
