03-28-2010 07:46 PM - edited 03-11-2019 10:26 AM
All,
While I'm very familiar with access lists, I'm not familiar at all with Zone Based Security Policies. With that in mind, could somebody give me a verbal desciption of the default Zone Based Security Policy setup on my Cisco 881W router? I've tried to disect it, but am totally lost. Here are the relevant config lines:
class-map type inspect match-any ccp-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol ftp
match protocol h323
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp extended
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
inspect
class class-default
pass
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
drop log
class type inspect ccp-protocol-http
inspect
class type inspect ccp-insp-traffic
inspect
class class-default
drop
class class-default
drop
zone security out-zone
zone security in-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-self source out-zone destination self
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip virtual-reassembly
zone-member security in-zone
ip tcp adjust-mss 1412
interface Dialer0
description $FW_OUTSIDE$
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip flow ingress
ip nat outside
zone-member security out-zone
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname XXXXXXXXX
ppp chap password 7 XXXXXXXXX
In addition to understanding how this is setup on my inside and outside interfaces, I want to add a rule that allows UDP 514 from specific Internet hosts via Dialer0) to the inside of my network in Vlan1. So, any additional comments on that would also be helpful.
Thank you very much for the help!
James E
03-28-2010 08:18 PM
High level explaination on ZBFW:
1) Determine zone for each interface, in your case: in-zone for vlan 1, and out-zone for Dialer 0 interface
2) For every interface to communicate with others, you would need to configure zone pairing. In your case:
--Traffic sourcing from the router towards the out-zone (dialer0 interface), example: VPN traffic outbound, ping out from the router, outbound telnet from the router, etc:
-- Traffic sourcing from in-zone (vlan 1 subnet) towards the internet (outside) - out-zone (out Dialer0 interface), example: host from VLAN 1 accessing the Internet:
-- Traffic sourcing from out-zone (Internet) towards the router dialer0 interface, example: when trying to telnet/ssh into the router from the internet:
3) Once you determine the zone-pair, you would need to determine policy for each of the zone pairing. From the above, the "service-policy" is the policy configuration that is assigned to that zone-pairing.
4) To configure policy, you would need to configure class-map to match the traffic that you would like to allow/inspect. For example: if you would like to allow http access from your internal zone towards the Internet, here is how you would configure it:
access-list 101 permit tcp any any eq 80
class-map type inspect match-any http-class
match access-group 101
policy-map type inspect outbound-policy
class type inspect http-class
inspect
service-policy type inspect outbound-policy
You can only assign 1 policy to zone-pair, so if you need to add more policy, you just configure more class-map and configure it under the existing outbound-policy map.
From the above example, if you would like to allow SMTP traffic outbound, you can add the following:
class-map type inspect match-any smtp-class
match protocol smtp
class type inspect smtp-class
inspect
OR/ alternatively you can also add into the "http-class" that was configured as follows:
match protocol smtp
Hope that helps. Please rate useful post as for every rating, Cisco is matching $1 for the Haiti Earthquake. Thanks.
