CiscoIPPhoneExecute and lamps
Answered Question
Mar 28th, 2010
Recently I have been playing with Cisco IP Phone Service.
I have a question about Cisco IP Phone Service XML object "CiscoIPPhoneExecute".
1) I know I can make a phone ring by this object, but what other things can you do with it?
2) Is it possible to force blinking Headset, Mute and Speaker lamp on IP phone somehow?
Thank you very much,
Taro
Correct Answer by Aaron Harrison about 7 years 1 day ago
That object allows you to either call a URL, or an internal URI.
The URIs are detailed in the IP Phone Services app notes for your version of CCM on developer.cisco.com.
You can do things like play sounds, automate key presses, clear call histories, etc... As far as I'm aware you can't control the headset/mute/speaker lights. Presumably this is because it would only confuse users and give the appearance of a 'fault' on the handset.
You would be able to control the MWI light...
Aaron
Please rate helpful posts...
Overall Rating: 5 (1 ratings)
Correct Answer
Aaron Harrison Mon, 03/29/2010 - 01:29
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
