2800 reboots while running CBAC
Mar 29th, 2010
I have a network where we are using 2811 running CBAC to a Hosted Call Manager Network. The 2811 is located in a centralised Data Centre, which connects to remote sites via MPLS network. We have had power issues (20 second outage) at one of the remote sites where the phones are located, switching at that site is 6500 with PoE switch modules. When this site has a power outage the 2811 reloads unexpectedly here is reboot message on the router.
System returned to ROM by bus error at PC 0x4437D078, address 0x50000000 at 03:03:26 UTC Mon Mar 29 2010
I don't think its traffic related to all trhe phones rergistering which is 140. As when I do a controlloed reset phones at another remote site whhich is another 150. That make 290 that register all together.
Call Manager version is 6.1.3
Router IOS is 12.4(21)T1
We are running BGP through the firewall to get to the hosted platform
Any Help would be appreciated.
Cheers
Chris
Giuseppe Larosa Mon, 03/29/2010 - 06:02
  • Hall of Fame,
    Founding Member
Hello Chris,
you can post sh ver and the crash info file  into cisco output intepreter tool to get an analysis of the issue
use dir /all to see the recent crash info files saved in flash
Hope to help
Giuseppe
Chris McManaway Mon, 03/29/2010 - 17:28
Thanks for your help. The Show ver goes into the output analyser and gives me an output re memory area tried to be accessed that is outside of memory range....
The Crash is not accepted by the tool. The only supported file close to this is Show crashdump which does not exist on the 2800 platform.
Any other ideas?
Cheers
Chris
