Turbo ACLs
Answered Question
Mar 29th, 2010
Dear All,
I need to implement Turbo ACL on 2811 router.
I tried to enable it by using access-list compiled command but it is not listing the compiled option under access-list command.
I have checked the Cisco docs and IOC command look-up too.
Current IOS in the router is Version 12.4(15)XZ (C2800NM-IPVOICEK9-M).
Kindly help..
Nitin
Correct Answer by cciesec2011 about 7 years 3 months ago
Turbo ACLs was an option, default is on, in Pix version 6.3.x but no longer available in version 7.x and 8.x
Overall Rating: 4 (4 ratings)
Giuseppe Larosa Mon, 03/29/2010 - 03:26
  • Hall of Fame,
    Founding Member
Hello Nitin,
I see the compiled option on following device:
sh ver | inc image
System image file is "flash:c2800nm-adventerprisek9-mz.124-7a.bin"
access-list compiled ?
  reuse  Reuse tables when compiling (for reduced memory requirements)
it may be a question of feature set. I don't see the option on a C3825 with SP feature set
sh ver | inc image
System image file is "flash:c3825-spservicesk9-mz.124-24.T.bin"
Hope to help
Giuseppe
nitsg.gupta Mon, 03/29/2010 - 03:39
Thanks Giuseppe,
I think due to voice feature image on the router it is not lisiting the command. i'll make an image upgradation.
I am not able to get the command on PIX/ASA also. Would be appreciated if you please check the same command  availability on PIX/ASA with image release 7.2 or later.
Nitin
Giuseppe Larosa Mon, 03/29/2010 - 05:58
  • Hall of Fame,
    Founding Member
Hello Nitin,
I'm not an expert of ASA/PIX but I think that turbo ACL is not supported over these firewalls
see config guide for ASA 7.2
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/traffic.html
I don't see mention of turbo ACL
firewalls need to inspect deeply packets so probably turbo acceleration is not an option
Hope to help
Giuseppe
Correct Answer
cciesec2011 Mon, 03/29/2010 - 09:41
