Is there a way to factory reset a SPA5xxG Series phone from the web interface or remotely?
David Hornstein Mon, 03/29/2010 - 06:25
  • Gold, 750 points or more
Hi Jon,
I am unaware, personally, how this can be achieved via CCA or the SPA525G GUI.
SPA525G, with firmware 7.4.3 installed on the unit, I would have to ask someone to press the following key combination, settings key, press 9 and then press 2.
Which wasn't what you wanted to hear.
regards Dave
Steven DiStefano Mon, 03/29/2010 - 06:43
  • Blue, 1500 points or more
So CCA has a Topology View.  In it, all the phones are shown.   You can highlight the phone, then 'right mouse click' it and the reboot selection can be seet (or reset, I forgot which it was).  But that will reset the SPA5xxx phone remotely.
The UC500 has a VPN server.  You can VPN (remotely) into the UC500 system with CCA and do this.  So this may solve the business requirement.
Steve D
I believe you are pointing here to 'reboot' the phone the TS wants to reset all defaults to the phone so he can start over (i have seen a few times that the phones looses their mind and start behaving weird, especially when changing the configuration a lot)
anyway if you are pointing to reset to configuration defaults, how can we achieve this using the provisioning system or something else?
icastrov Tue, 03/30/2010 - 03:04
  • Cisco Employee,
I'm afraid that there's no way to factory reset a SPA5xxG phone remotely...
Thanks!
-nacho
Steven DiStefano Tue, 03/30/2010 - 06:22
Van,
you are right about reboot.  Sorry.   But I just had a light go on.
The phone itself has a Setup button.   press that and scroll all the way down to menu #7 which says Factory Reset
maybe this was there all the while for us to use.....
jonathan.vaught Tue, 03/30/2010 - 08:58
Thanks for the useful feedback - what I am trying to acheive is apparently not possible without physically being in front of the phone to press the necessary buttons to return to factory default. This would be a great feature - especially if you are trying to move toward a zero-touch installation as we are. thanks.
CTRLITINC Tue, 04/13/2010 - 18:25
You can create a baseline by manually setting the phone to factory default. You can then get the XML by using:
http://myPhoneIpAddress/admin/spacfg.xml
You can then use this default configuration file and use the following Provisioning URL to upload the baseline XML to a web server, then use the following url to resync your phone:
http://myPhoneIpAddress/admin/resync?http://myHostedWebServer/spaconfig.xml
myPhoneIpAddress = You phone you wish to reset
myHostedWebServer = A web server that the phone can access.
spaconfig.xml = The baseline xml file from a factory reset phone. This will be the XML you upload to a web server your phone has access to.
HTH,
Steve Wofford
Call Ctrl Call Manager for
SPA900 - SPA500 IP Phones
