NAT from private IP address
Answered Question
Mar 29th, 2010
We have an ASA 5550.  How do you write a NAT statement from the inside private IP 192.168.100.1(server) to a public IP address?
Thanks.
Diane
Correct Answer by Jon Marshall about 6 years 10 months ago
dianewalker wrote:
Thanks for your prompt response, Jon.
Another question: Instead of NATTING each individual private IP address to each individual public IP address, can you also NATTING the entire subnet?  For example, can you do this?
static (inside,outside) 192.168.100.0 netmask 255.255.255.0
Also, would you recommend natting each individual IP address or the entire subnet?
Thanks.
Diane
Diane
Apologies, i missed your response.
No your static wouldn't work because with static NAT as above you need a one to one mapping so with your static above the firewall would have no way of knowing which 192.168.100.x address to map to the public IP.
You could do this -
where the public IP subnet has a subnet mask of 255.255.255.
For static NAT i would recommend only Natting the IPs you have to for security purposes as much as anything else.
Jon
Thanks.
Diane
Diane
static (inside,outside) 192.168.100.1 netmask 255.255.255.255
Jon
Cisco are currently donating money to the Haiti earthquake appeal for every rating so please consider rating all helpful posts.
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Mon, 03/29/2010 - 08:13
Thanks.
Diane
Diane
Jon
dianewalker Mon, 03/29/2010 - 09:22
Thanks.
Diane
Correct Answer
Jon Marshall Mon, 03/29/2010 - 14:36
Thanks.
Diane
Diane
You could do this -
Jon
