WAE-612 Console Cable Confirmation
Mar 29th, 2010
So I see it's the old serial RS-232 connection :-(
Does the standard Cisco console cable do the job in terms of gaining access to line con0 ?
I have some old DB-9's lying around but not seeing any output with standard settings i.e. baud-rate etc...
thanks
Zach Seils Mon, 04/12/2010 - 07:29
Ajaz,
The standard Cisco concole cable will work.
What settings are you using?
Zach
AJAZ NAWAZ Mon, 04/12/2010 - 07:49
Hey Zach - How are you?
In terms of the console cable, I was unlucky enough to pickup a dud DB9 connecter. As soon as I changed that - bingo!
It did have me going though for a while :-/
Ajaz
