cisco call manager Express
SUNUTECH
Pouvez vous m’aider à faire cette configuration. Au fait je veux que l’utilisateur compose 9999 et qu’en réalité le système appelle un numéro précis sur l’international . Mais j’y arrive pas.
Can you help me to make this configuration. With the fact I want that  the user composes 9999 and that actually the system calls a precise  number on the international one. But I do not arrive there.
28 Replies 28
Brandon Buffin
So, do you want to dial 9999 and have the system translate that to another number? If so, use the num-exp command:
num-exp 9999 91234567890
Hope this helps.
Brandon
YES you understand ! what  is the command I use to do this ?
thanks for your answer !
The command is:
where 91234567890 is the full number to which you want to translate 9999.
Hope this helps.
Brandon
Thanks let me try the configuration !
do I need to configure dial-peer for this ?
You will need a dial peer but this config does not go under the dial peer.
  If I use Cisco MCS 7845-H2 Unified Communications  Manager Appliance what will be the configuration?
NEED HELP !
do I need to configure something in the gateway (router) ?
You originally mentioned Callmanager Express. Is this a CME router or a gateway for a CUCM? If for CUCM, is it H.323 or MGCP?
Brandon
Hello
it's a mistake it's CUCM VERSION 5 . and   gateway for a CUCM. it's for CUCM, it 's H.323
Brandon Buffin
OK. Is the gateway H.323 or MGCP?
Brandon
YES what i need de configure ?
