c831
Mar 29th, 2010
I have a c81 that used to run  ios c831-k9o3sy6-mz.124-19.bin but it crached after a d-ram failure i have replased the default ram but no mather what now the router only detecks the new chips to be 16mb  adding the total to 48mb  i tryd several types orginal and 3-party ram
any ideas
Kristan
buchholr Sat, 04/03/2010 - 22:04
There are two generations of the 831.  The earlier generations only had 32 MB onboard, and the later versions had 48 MB onboard.  However, both only permitted a 16 MB card to be installed int the DRAM slot.
Here is a link to the memory upgrade documentation for the 800 series routers:
http://www.cisco.com/en/US/partner/docs/routers/access/800/hardware/notes/800upgrd.html#wp41897
It sound like your router is doing what it is supposed to do in terms of the memory in the DRAM slot.
You may have had part of your onboard memory fail.
HTH,
Robert
kristiant Tue, 04/06/2010 - 07:59
i found out about this some days back, but i now starting to wonder if it`s wasnt the expand memory that was faulty but
some of the onboard memory itself.
As i told i used to use c831-k9o3sy6-mz.124-19.bin and this version requires 64mb dram so i have had to got the newer
version of the router and whit the expasion ram adding it up to a total of 80, so the only logical explanation i got at this point is
thats the onboard memory itself thats faulty.
Kristian
