N5k to N2k channel-groups error
Answered Question
Mar 29th, 2010
  • Bronze, 100 points or more
I am getting this error on E1/7 and E1/8..what am I doing wrong?. Thx
interface Ethernet1/7
  switchport mode fex-fabric
  untagged cos 0
  fex associate 101
interface Ethernet1/8
  untagged cos 0
  fex associate 101
N5k-Edge1-DC(config-if)# channel-group 201
command failed: port not compatible [port mode]
interface port-channel201
  description TO-N2K-ROW-1
  vpc 201
  fex associate 101
fex 101
  pinning max-links 1
  description FEX101
  type "Nexus 2148T"
Correct Answer by allan.thomas about 6 years 12 months ago
The problem here is that I suspect that the channel-group was created before the interfaces were configured as fex-fabric interfaces, and consequently the channel-group is not specified as a fex-fabric port-channel.  The simplest solution without have to remove the port-channel, is to simply go under the port-channel inferace and specify 'switchport mode fex-fabric', then go back under the physical interface and add the channel-group again.
Allan.
Hope this helps, pls rate helpful posts...
Overall Rating: 5 (2 ratings)
Correct Answer
allan.thomas Mon, 03/29/2010 - 14:38
  • Blue, 1500 points or more
Allan.
