4510 Switch Question
Mar 29th, 2010
Greetings - Does anybody know if the modules on a 4510 are both hot-swappable and plug and play?  We have some 4510's and have found that we need to add new modules to get more available ports.  I just need to know if I will need to shut the switch down before I install the new modules into the switches or if I can just plug in the new 48 port module and be able to configure the ports without a restart.
Overall Rating: 5 (1 ratings)
mpozorski Mon, 03/29/2010 - 11:41
Thank you for the information Collin.  I was a little concerned with the idea of having to take the switch down to add another module.
adrianoden Mon, 03/29/2010 - 11:42
It goes without saying though that I would recommend doing it during a down time or maintenance period. In case mumphrey decides to show up.
