WLC service-group settings
Mar 29th, 2010
After checking the WLCs at several sites using the WLC Config Analyzer, one of the errors that came up was that the service-port interface was invalid because it was set to 0.0.0.0. We're not using the service-port interface, so how should this be set? In the web interface, if I uncheck DHCP, it wants a real static IP address... should I use 127.0.0.1? Do I need to do this in the CLI?
Kayle Miller Mon, 03/29/2010 - 12:19
  • Silver, 250 points or more
Generally I set them to something so that some stuff like WCS & Config Analyzer don't complain about it. I wouldn't set it to 127.0.0.1.; Although if it's a WiSM module then they should be configured to match the WiSM VLAN in the switch chassis otherwise the WLC can generate lost heartbeat alarms.
Typically if my internal network is a 10.x.x.x network I will use 192.168.1.(last octet of management address), then reverse that as necessary. The service port is for out of band management, which mean it generally isn't connected to any unless you need an alternate to the console port.
As fo setting it, you can either set it via the gui or via the cli
hope this helps.
spfister336 Tue, 03/30/2010 - 08:46
If it's not a WiSM, and we don't have a WCS (yet anyway), is there any need to change it, other than stopping the error in the Config Analyzer? I'd like to do that, but I'd probably need more justification to actually do it.
Thanks!
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
