SA500 Firmware Upgrade
Mar 29th, 2010
With the standby feature for firmware upgrades. Is the device configuration maintained for this update or does it factory default all the setting so you have to re-load your specific configuration?
Mike
misouder Mon, 03/29/2010 - 13:42
Nevermind, found the answer in a technical document.
To confirm you can choose to do the firmware update and keep your configuration or choose firmware update with factory reset in which your configuration will be cleared to factory settings correct?
Mike
jamesirish Fri, 04/02/2010 - 12:46
When is the next version of the firmware going to come out for the SA520W?
