CUPS upgrade switch version fails
Mar 29th, 2010
I'm upgrading CUPS 6.0.5.10000-13 to 7.0.2.10000-36 which I have downloaded from CCO.
I restarted the server and when I apply switch version command from CLI to swtich to ver 7, it doesn't do anything.
Has any body experience this kind of issue? This is a standalone lab installation so physically there's no CUCM connected. I have restored production CUPS backup on it and wants to upgrade to ver 7.
Thanks in advance,
Sak
Aaron Harrison Mon, 03/29/2010 - 14:03
  • Community Spotlight Award,
    Member's Choice, May 2015
Maybe try:
Utils system switch-version nodatasync
Aaron
sakengineer Mon, 03/29/2010 - 14:10
Thanks Aaron, I will give it a shot and update the thread.
sak
htluo Mon, 03/29/2010 - 14:58
  • Red, 2250 points or more
This is most likely CSCsl59162.
I might be wrong, but I don't think nodatasync would fix the problem.
"nodatasync" parameter is used on CUCM to turn off UFF (User Faced Feature) synchronization.  UFF means, MWI, Call Forwarding, etc..  Since CUPS does not have UFF, this parameter shouldn't make any difference on switch-version command.
If "nodatasync" didn't fix the problem, you may open a TAC case and provide bug ID CSCsl59162.  TAC engineer should be able to apply workaround per the bug.
Michael
http://htluo.blogspot.com
Aaron Harrison Mon, 03/29/2010 - 22:27
Michael, I'm sure you are not wrong
I imagined UFF (in the CUPS context) would be stuff that isn't configurable via the Admin interface; so things like user's contact lists, setting to show calendar presence, etc etc... I guess that's not the case?
