Analog phones with CUCM
Hello all,
Looking to migrate many analog phones from a failed PBX using CUCM to register them.. There are more than an handful of phones in the hundreds.. Is the FXS module WS-X6624 that hold the most analog module are there any other MGCP hardware that can support a greater amount of analog phones per module ?
allan.thomas Mon, 03/29/2010 - 15:52
Hi Tim,
There are number analogue gateways, however the only significant comparision is the VG224, which also offers the port density that you are looking for.  It is specifically a 24-port 19" inch rack mountable chassis and not network line-card or module which has scalability issues.  Take a look at the following datasheet:-
Hope this helps, pls rate helpful posts.
Related Content
