How to get Celan Access (NAC) reports about users stucked in Temporary role?
Answered Question
Mar 25th, 2010
I am using Clean Access 4.7.2.
If a user does not mett a requirement and is unable to remediate, he is stucked in the Temporary role.
I checked the "Device Management > Clean Access y Reports" but this does not show any user with failed status with red flag.
The report shows successfull connection with green flag only.
How can I obtain report on the CAM about failed checks?
Csaba
Correct Answer by netjustin about 6 years 12 months ago
We had this problem and were told to press Cancel (and then confirm) in the top right corner of the Agent after failing posture assessment. When we did that, the complete report showed up in CAM within seconds and could then be used to manually remediate the machine.
Hope that helps!
Correct Answer
netjustin Tue, 03/30/2010 - 08:09
Hope that helps!
CSABA GARAI Tue, 03/30/2010 - 12:36
Thanks for the reply.
It is working.
It would be more sofisticated  if reports about failed status could generated automaticaly.
Thanks again.
Csaba
netjustin Tue, 03/30/2010 - 12:58
I agree, it seems like a design flaw. I seem to remember failure reports sending automatically in earlier incarnations of the program but somewhere along the line that stopped.
Related Content
